- Jan 15, 2005
- 4,327
- 1
- 0
Hey James,
I'm really sorry about what happened to your computer. And I didn't
meant to cause any damage or harm on purpose. However I do beleive
that I can help you get your files back.
Again the problem started when I suggested that you install AdAware
to remove any spyware/malicious programs that your computer might have
had. When you did the scan, several "dangerous files" (or so AdAware
calls them) were quarantined, and something got corrupted in the
Operating System
To Mr. Higgins:
Mr. Higgins, I'm extremely sorry for any damage I've caused to your
computer. James informed me that you had some important documents in
there that you need. Please accept my utmost apologies.
I've talked to several people and posted on several message boards
regarding how to deal with this situation. The majority of the asnwers
I received back was that the Operating System was infested with
spyware, that AdAware may have taken a part of the OS out with it when
quarantining.
I do feel that I can help regarding this matter, but please
disregard this advice if you wish to. I understand the feelings that
you may have toward me because of what happened.
I have some proposed solutions (which you can try if you wish). Please
look them over if you wish to.
1) Boot up into Safe Mode (hit F8 when "Windows 95" loading screen
comes up) and run AdAware, and unquarantine the quarantined files.
Then try rebooting into Windows 95 and see if that works.
2) If this doesn't work, then try booting to safe mode and
uninstalling AdAware from there.
3) If safe mode didn't work, then I think that the OS is completely corrupted.
I think the first priority is to rescue the important documents.
Easiest way to rescue the files would be to put the harddrive (in
Slave Mode) in another computer that works and copy the files there.
But keep in mind that the existing drive may have viruses and you may
be transferring viruses into the other computer so be sure you're
running a virus scanner while you do this.
Here's what I think the configuration would look like
PRIMARY_IDE:
Master = Existing Harddrive (on the working computer)
Slave = Harddrive (from the broken computer)
SECONDARY_IDE
Master - Existing CD/DVD Drive
Slave - Existing CD/DVD burner
4) Once you copy your files into the other harddrive, I would
reinstall Windows (95, 98, or 2000) on the harddrive (from the broken
computer) and then put it back into the computer*.
*I don't think the problem is hardware related, so I do beleive a
reformatting of the OS can solve this issue.
Please accept my utmost apologies Mr. Higgins. Again, I'm sorry for
any damage which I might have caused (directly or indirectly).
James, I hope to hear back from you.
Originally posted by: lxskllr
That sounds pretty good.
I wouldn't beat yourself up to badly over the situation though. The friends father should be mad at himself for letting his computer get to the stage it's in now. It would be the same as you coughing up blood for 2 years before going to the doctor, and then getting pissed at him when he tells you you have advanced cancer.
I hope that this doesn't affect your friendship, but it may be the best thing that happened to them if they'll learn from the experience, and begin to take a proactive approach to computer maintainence.
That taught me a lesson. Now I'm backing up all those programs I've been working on (and that 3D RPG I've been working on for a full year) because ... well, my Maxtor is starting to make clicking noises >_<.Imagine what would have happened if this was a hardware fault like the HDD dieing, and not just a software thing?
Originally posted by: The Pentium Guy
Now that, is an insane idea!
"rename C:\Program Files\Lavasoft LavaSucks "
Sound good?
This would make him feel better thoughPsh, Lavasoft doesn't suck. The PC it's trying to work on does.
Oh. Sorry, I should have explained a little more clearer. He installed adaware all fine. He scanned and quarantined stuff (apparently there was a LOT). Then he did an update and scanned again.....this time, after he quarantined, his computer went a lot slower (which is weird, considering it's slow enough already)....and then he got an error (he wasn't sure what it was), it crashed, and he couldn't boot up windows properly again.So what exactly was the deal? Did he actually get rid of any spyware, or did he merely install Adaware?
GreatWin95 you said? Option #6 is for the plain old Command Prompt. I think option 5 is command prompt only - no autoexec.bat or anything.
I do beleive that a Windows reinstall session is the best solution, after backing up the files. I don't think repairing the registry will help in this case, honestly, it's nearly 10 years old and who knows how corrupted it is? Hell I get a lot of crap in my registry after 6 months!I don't remember if Win95 has anything for registry repair. Other option is the system.da0 and user.da0 files.
Type in:
<Clipped>
Other thing to do - hook their hard drive up to your system, burn their important files to a CD, and then maybe reinstall Windows.
Alright I've talked to him. It seems as though his dad is extremely mad at me because he had some office documents in there that he needed.
How's this?
Hey James,
Operating System
To Mr. Higgins:
quarantining.
PRIMARY_IDE:
SECONDARY_IDE
Sound good? I mean his parents are really mad at me, because they had some seriously important office documents.
-The Pentium Guy
I got him to install Opera earlier (I prefer it over FF and IE for some reason, but definately over IEI would also suggest that you tell the poor guy how to avoid spyware...that's the best spyware killer out there.
