Info Adata online flash drive recovery / repair / format program, I found a guide!
VirtualLarry
56,587
10,227
http://www.flashdrive-repair.com/2017/10/adata-usb-flash-drive-online-recovery-tool.html
I never could get Adata's site to spit out the necessary programs that you need to recover / re-format / re-flash their flash drives. It requires you to enter a serial number, but the serial number on the drive itself, is longer than the website form accepts.
This guide spells it out, if it begins with a numeral, enter the first 8 digits. It worked!
I was able to use the SMI High-Level Format Tool that it spit out for my older Yellow/Black Adata UV128 16GB flash drives, several of which I purchased, during a time period in which the packaging did NOT indicate compatibility with Windows 10, and subsequently, the drives are not properly detected under Windows 10, and fail to show up as a drive letter. Something about cannot load driver.
Anyways, after using a Windows 7 64-bit machine (they do show up under Windows 7 properly, and Linux, and BIOS), I was able to use the SMI formatting tool, to apparently re-flash the firmware and re-initialize the drive, so that now, it works in Windows 10!.
So happy to finally find a solution, and now I'm not out the money for these flash drives. If only I could find the few that I opened before that didn't work in Windows 10, so I could flash them as well.
Reactions: cbn
hojnikb
562
45
I highly recommend this russian site (just use google translate)
https://www.usbdev.ru/files/
for broken flash drives. Pretty much any manufacturer tool available, it's just a matter of finding it.
Might not be as easy as using adata's tool, but most manufacturers dont provide such tools anyway, so you have to resort to factory tools used by them.
