imported_Kiwi
I have had a couple of different Thermaltake CPU HSFs that came with speed controls, each uses two wires only (with the plug that looks like a two-pin version of a Floppy plug), and my case fans use standard 4-wire Molex jacks. I have a 120 mm, normal 12v fan that isn't terribly noisy on its own, but it does seem to add to the overall harmonics of total noise to a relatively unreasonable extent.
Would there be a truly simple modification I can make to put either one of my Tt controls to work to adjust that particular case fan?
