adapter to replace laptop dvd/cd drive with hard drive?
her34
581
is there a way to replace the optical drive of a laptop with a hard drive? perhaps some sort of adapter that's the same size as a laptop cd/dvd drive, but let's you put in a hdd?
corkyg
Elite Member | Peripherals
27,370
240
That all depends on the brand of laptop. Some Gateways replaced the LS-120/floppy module with a 2nd HDD. IBM, I believe, has a 2nd HDD for the CD drive module. There is no standard for this - you need to explore each brand and model.
The best generic way of getting a 2nd HDD is an external Firewire or USB 2 case for 3.5" drives. That's what I use on my new HP dv1000.
her34
581
but many different brand laptops can take the nec slim line dvd drive. you can't use a hdd module in the same shape as the nec drive?
corkyg
27,370
240
It is more than shape. Module carriers/caddies are not generically universal. In addition to the form factor, the electrical connector for power and data must be an exact match.
corkyg
27,370
240
Well, there are second hard drive modules for specific laptops. Example here - some Dell models.
HDD
and . . .
EZ-Bay
Google is your friend.:)
