Solved! Adapter Cable for NVMe SSDCard
Robert Snow
I have an NVMe SSD Card, M2, that I need to read or copy files from. I was hoping there might be a cable or device that can be conected to my porable compuet by using a USB connection.
Bob
Solution
Solution
I did order this. Does it snap shut or do you have to use screws? I loose screws all the time. But either way, it should be here Sunday.
Thanks for making my day.
Bob
Bob
I don't have that one, so I can't answer your question. I didn't see the one I have.
