ADA3800DAA5CD max of 1.35V on 939Dual-SATA2?
stormont
43
I thought that all X2 3800+ CPUs could be set to run at voltages between 1.35 and 1.4V? I have a X2 3800+ that I can only set to a max of 1.350V in my BIOS, not 1.4V like many others can (without any VCORE mods) I've tried both BIOS 1.2 and 1.3. The CPU has the following markings:
ADA3800DAA5CD
CCBWE 0528XPMW
No matter what BIOS I try, the "Processor Maximum Voltage" setting in the BIOS is locked at 1.350V. Changing to "Auto" only allows me to select up to 1.350V.
BIOS screenshot
CPU-Z 1.30 reports the following:
CPU-z screenshot
I made sure to take a screenshot when the voltage was at the highest. It actually fluctuates between 1.360 to 1.392. So I guess my 1.350V max in the BIOS is being ignored? Is this how the Manchester E6 CPUs are supposed to work? If so, that is fine, I just want to make sure that something isn't broken somewhere because I do not have the ability to select 1.40V in the BIOS like many people with this board do without having to perform a VCORE mod.
