Acura TSX, Hyundai Sonata V6, or Subaru Legacy GT?
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
TSX or Legacy GT, but I would compare the interiors on both firsthand. Yes, the Legacy has the HP and AWD advantage, but Acura vs Suburu interiors are vastly different.
Looked at the G35?
amol
11,680
Looked at the G35?
Looking at his budget, the G35 may be a little too expensive.
Though, he can get a 2003 or 2004 model year :)
b0mbrman
29,470
Logic dictates the Legacy should wipe the floor with the TSX, but the Acura seems to be holding its own in car reviews...
I'm not in the market for a sedan so I haven't test-driven either myself...but you should...
CoolTech
2,345
i test drove the 4 cylinder sonata yesterday, it was ehh, they said they dont get the V6s until mid june, bah
NutBucket
27,165
640
Mainly because of luxury features and interior quality. I see nothing wrong with the Leg GT interior although I haven't checked out a TSX.
OOOOO! The TSX has navigation and HIDs! It must be better. I hate to say it but typical Honda bias. If you check out the reviews the Acura is all asthetics and the Leg is all about driving. I do wish it had some better shocks though. It does strike me as begin a tad floaty.
fs5
11,774
get the Hyundai Sonata V6, #1 reliablity, #1 class, #1 brand whoring!
Ns1
55,420
1,600
legacy for power, acura for class
hyundai if you want the worst shifter known to man. yes ladies and gentlmen, a shifter WORST than the corvette.
K1052
53,356
47,767
Legacy GT.
Fast, AWD, comfortable, good gas mileage, somewhat of a rarity on the road, and reliable.
GTaudiophile
29,767
33
I test-drove both the TSX and LGT. The LGT is a performance sedan. It has power and handling. The TSX has all the gadgets and goodies, better build quality, and better resale. It's also a real luxury badge. In the end, I bought a Mazda 3S!
Edit: In terms of performance, an MZ3 with a 5-speed will easily outperform and out handle an Acura TSX with an auto tranny.
