justin4pack
I just picked up a loaded Acura TL and everything works but the climate control. When u engage auto mode or use manual mode through the navi, u can hear things turn on but no air comes out. Any one know much about the tl's?
I have an 04 Accord and that happened to me last September. Simple 5 minute swap. Believe the part runs around $22 for a generic from Autozone/your favorite B&M auto parts store.
As a heads up - make *sure* that you examine the generic part. (IE, what you are buying is indeed a generic part) I bought a replacement from Autozone and inside was the exact same part. (OEM) I thought it was odd but didn't think much of it. The "new" part didn't work, so I tried replacing the blower motor too. Only after about 2 hours of headache that I went to a diff Autozone and tried another generic blower motor resistor - this time an actual new generic - that it worked. (Long story short, some a-hole swapped out his non working OEM part with the generic and returned it back to the store) Nothing like wasting a Sunday morning. :|
Damn some people are cheap. WTF?
Cool I'll try the resister. How about resetting the navi lol. I called the dealer and they gave me a 4 digit code tried it and gives me a incorrect pin... dealer said they have no idea.
