Actual dimensions of 27 inch 1080 monitor?
Wedge1
905
I am trying to figure out if the 27 inch BenQ XL2720Z will fit on my corner desk where i have a hutch on the right and left sides (that I know will be obscured to some extent).
Could somebody tell how many inches in H x W the panel needs?
Thanks,
Wedge1
Tweakin
2,532
Google is a wonderful thing:
Height: 21.6 inches
Width: 25.3 inches
Depth: 10.7 inches
Weight: 16.5 lb
Wedge1
905
Is 21.6 the actual panel height (disregarding the stand, in other words)?
That seems rather large. That makes the panel height almost 2 feet.
BenQ web site states display size in mm as: 598 x 336
25.4 mm = 1 inch
336/25.4 = 13.2 inches height for display (seems accurate)
13.2 inches + bezel = actual size I am looking for
Could somebody measure their panel, including bezels on each dimension, and report back. It would be greatly appreciated.
96Firebird
5,741
340
Bezel looks to be a uniform thickness all around, so you can do the math on the height given the width dimensions above.
Bezel thickness = [Width (25.3in) - Panel (598mm/25.4mm/in)]/2
= (25.3in - 23.54in)/2
=.88in
So adding the bezel thickness onto the panel height...
Total height = (336mm/25.4mm/in)+(2*.88in)
=14.99in
