Active W-LAN causes noise in my speakers ?!?
Nickel020
I recently got me a D-Link DI-614+ W-LAN Router and a DWL-120+ USB W-LAN adapter. Since I got it I noticed quiet a bit of noise in coming from my speakers. After some testing I am now 100% sure that the source of the noise is the W-LAN, as when I switch off the Router and unplug my W-LAN adapter form my PC the noise stops. The loudness of the noise also seems to depend on traffic: When the internet connection is idle, it's fairly quiet, but when I'm downloading something it gets much louder.
Has anyone had this problem and/or knows how to get rid of the noise? This starting to get really annying...
Thx
To get rid of the noise, you gotta get rid of the interference. And the interference in this case is the radio waves that your wireless router is broadcasting. Try changing the channel the router is using. If that doesn't work, you're basically sodomized. try another router or other speakers.
