I'm working on creating a new security group that only our department is a part of so they can unlock/reset/change passwords without having access to change group memberships, etc. So far I have the security group setup and have applied it to our users OU.
Only problem is that at some point in history certain users had their 'inheritence' checkbox unchecked so they are not getting the correct security permissions and so the regular users in our department cannot unlock some of our users.
Is there any way to reset all the inheritence on an OU and it's objects kind of like file security where you can force the resetting of permissions?
Thanks! I've been trying to figure this one out for a while.
Update:
Solution posted below.
Update:
