- Aug 27, 2002
- 10,043
- 2
- 0
I have an AD test lab, in it are 4 machines and a network printer.
machines are called:
adtestserver
testprintserver
testXPpc
testNT4pdc
an nt4 domain and an AD domain using 2 way transitive trusts. the share permissions to the printer include domain users from the AD domain.
currently the printserver is in the NT4 domain and the XP pc is in the AD domain (2000 native mode) as it will be when we install our AD system live. (we have many pc's that will slowly be migrated into the AD domain.
I can use the UNC path and instantly connect to the printer on the XP pc, however when I use the add new printer and select the option to browse the tree for printers I only get the domain name for the tree, no OU's are listed. I fought this for a few hours last night, I came in this morning and it worked fine. I restarted the XP pc, and now the same thing happens, I only see the domain name for the tree, no OU's are listed.
We have some 200 printers and it would be a lot simpler (for the users) to drill down the AD tree to thier Department Printers OU to install printers as needed, than for us to have to remote their pc and connect using the UNC path. (this is also a requirement from our manangent that this feature of AD be available)
Has anyone else had any issues of not being able to search the AD tree to install printers on a relatively large domain by using dedicated Printers OU's located under Department OU's? It appears that after ~ 2 hours that I can browse the AD tree fine.
As to the logon script question. We use kixtart for running our logon scripts for our current nt4 domain. Personally I love it and it has worked well for us, however our management wants us to use generic batch files when we install AD(no reason was given, and they seem to be dead set on dumping kixtart). I have extremely limited batch file writing skills and wondered if someone would mind giving me an example of a simple dos based batch file that would do the following. (taken from our kixtart script, modified for security reasons, and truncated just because it's for example purposes)
if ingroup ("Domain Users")
; All users
settime "\\PDC"
use x: "\\data\Apps"
;run "x:\program.exe"
;Copy files for specific ap printing...
if Dir("$sysroot\executable.exe") = ""
copy "\\program\execytabke.exe" $sysroot
endif
if Dir("$sysroot\file.text") = ""
copy "\\program\file.text" $sysroot
endif
; End all users
; Department shares
if ingroup ("CBO")
use s: "\\fileshare\cbo"
endif
if ingroup ("IS")
use s: "\\fileshare\IS Department"
endif
; End department shares
adtestserver
testprintserver
testXPpc
testNT4pdc
; All users
settime "\\PDC"
endif
endif
; End all users
; Department shares
if ingroup ("CBO")
endif
if ingroup ("IS")
endif
