Acrylic window rubber molding question
Verdugo
Hi,
I need to know where i can fin a rubber molding with wider gap on the case side. I'm installing a window on a case that's thicker than your usual 1/16. This case is actually closer to 1/4 of an inch. The other side of the rubber molding is still the usual 1/8 for the window itself. Thanks for your help.
Wow! What is the case made of? Wood? Plastic? If it were metal, it would weigh a ton.
Oops. The case in question is the Antec P180. The case is double sided and there's a plastic sandwiched in between that helps make it quiet. I want to install a window but i'm facing the fact that it's too thick. I don't want to hold the window with screws.
