Hi all,
a while ago I bought the Acoustic Energy Aego M 2.1 (great speakers) and they still work perfectly when plugged into my PC.
My only problem is that I cannot make my headphones work with them- if I plugged the headphones into the 3.5mm jack on the sub- woofer there would not be any sound coming out of them.
My headphones are working perfectly when used with other devices or even when plugged into the PC but since my sound card is at the back and is inconvenient to me to duck all the time I wanted to be able to connect them directly to the sub-woofer.
Is that the purpose of the 3.5mm jack on it or is it for something else? Is there any whay I can use my headphones when plugged into the speakers?
Here is a link with the specifications of the speakers:
http://www.acoustic-energy.co.uk/Default.aspx?pagename=Aego-M-loudspeaker
Thanks for any help.
