acme.sh not adding / after domain when fetching verification data
14,074
Certbot stopped working on my server a while back so I'm trying to convert everything over to use acme.sh with a helper script to generate the apache config entries etc...
And it's really giving me trouble. Basically for sub domains I added an alias for the /.well-known/acme-challenge for each sub domain so that it points to the main, but since some of the top level domains are showing as already verified, I think it's skipping the part to create the folder there.
But also, it's not adding the / and trying to go to an invalid domain. See error below:
Code:
[user@server03 acme.sh-master]$ ./acme.sh -f --issue -d example.com -d www.example.com -d forums.example.com --webroot /home/user/www/example.com/www/
[Mon Mar 15 20:09:30 EDT 2021] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Mon Mar 15 20:09:30 EDT 2021] Multi domain='DNS:example.com,DNS:www.example.com,DNS:forums.example.com'
[Mon Mar 15 20:09:30 EDT 2021] Getting domain auth token for each domain
[Mon Mar 15 20:09:31 EDT 2021] Getting webroot for domain='example.com'
[Mon Mar 15 20:09:31 EDT 2021] Getting webroot for domain='www.example.com'
[Mon Mar 15 20:09:31 EDT 2021] Getting webroot for domain='forums.example.com'
[Mon Mar 15 20:09:32 EDT 2021] example.com is already verified, skip http-01.
[Mon Mar 15 20:09:32 EDT 2021] www.example.com is already verified, skip http-01.
[Mon Mar 15 20:09:32 EDT 2021] Verifying: forums.example.com
[Mon Mar 15 20:09:34 EDT 2021] forums.example.com:Verify error:Fetching https://forums.example.com.well-known/acme-challenge/MlP0f6CGg7vi7JlWDNTwVmsTA6PtstN8t7yrkwFPE8M: Invalid host in redirect target
[Mon Mar 15 20:09:34 EDT 2021] Please add '--debug' or '--log' to check more details.
[Mon Mar 15 20:09:34 EDT 2021] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
To add the alias I edited the virtualhost for the forum host, so that it goes to www, as acme.sh puts it there. (or normally would...)
Code:
<VirtualHost *:443>
    ServerAdmin webmaster@iceteks.com
    DocumentRoot /home/user/www/example.com/forums/
    ServerName forums.example.com
    ServerAlias forums.example.ca
alias "/.well-known/acme-challenge/" "/home/user/www/example.com/www/.well-known/acme-challenge/"
<directory />
Is there a way to make this work properly?
Also how do I go about adding another subdomain after the fact? This is where things seem to break down, because the top level domain will already have been verified so it's not going to add the proper files to that folder, but then it still wants to verify the new sub domain. I know there's a way to do it with DNS too but that sounds like an even bigger pain as you need to setup dynamic DNS, which I've looked into before and it's super tedious and needs to be done for each individual domain and there is lot of legwork involved.
14,074
After lot of painstaking troubleshooting and fiddling around I managed to get it going. Lot of stuff makes no sense, I would try one thing, it would not work, put it back the way it was originally, then suddenly it would work. This whole process has been a nightmare.
It's the domains that have subdomains going to different directories or different servers altogether that make it a real nightmare because each one needs to be validated.
But here's one thing... how do you deal with subdomains that use http authentication?
I have a test.domain.com site which is a test version of the site and it just uses a basic user/pass. It's basically just to stop anyone from somehow accidentally trying to use the test site. But because there is authentication I think it even overrides to alias to the .well-known folder in the main domain.
I had to remove the auth for now and put it back, but next time it needs to renew this will be an issue. I'm trying to automate this as best as I can.
