- Mar 27, 2009
- 12,968
- 221
- 106
http://www.guru3d.com/article/overclock-radeon-5970-guide/3
According to this Guru of 3d HD5970 overclocking review they were able to squeeze 380 watts through a 6pin/8 pin power connector combination.
On the first page of the review it mentions needing enough amps on the 12v rail.
Is there a formula for determining how many amps are needed to exceed the 300watt limitations of a 6pin/8pin?
A 1200 watt PSU was used in the test but I would hope something much smaller could be used to obtain the same result.
