- Feb 21, 2001
- 33
- 0
- 0
Trying to fix this system for a friend. The problem specs: occasional loss of the mouse (most likely a bad USB connection which seems to be isolated to port 1 of 4), and occasional system freeze ups. The system freeze up problem was solved rather quickly, after about the second bootup when I noticed the heatsink fan sputtering and not spinning. The problem I'm left with, however, is that I can't get the mouse to work at all, and I can't get the keyboard to work after booting up into W98 normal mode.
The really puzzling aspect is, the keyboard will work to get into the BIOS setup and also into W98 safe mode. It won't work at all (keyboard indicator light doesn't even come on) after booting into W98 normally.
This system only has USB ports for keyboard and mouse. Unfortunately, my friend only gave me the case without the Acer original keyboard and mouse. Could that possibly make a difference? I don't know that much about USB. Have USB protocols changed since their inception? I could see that making a difference, in as much as the USB keyboard and mouse I'm trying to use are very new, and this system came out in 1997-98, the early years of USB.
Could Acer have possibly made the keyboard/mouse proprietary with their system, so that only their stuff would work?
