Svnla
Local CC store has an ad for 3 days sale <today until Sat> and it has Acer 22" WS LCD for $290 after $10 MIR. They also have coupon at the checkouit desk for instant $25 gift card.
$300 price - $10 rebate - $25 gift card = $265 plus taxes. Not bad at all
Model AL2216WBD. I did some search on google and pricegraber and the reviews are positive and it is a good deal.
I have $15 off coupon and I will try to use it to buy another one. If I can do it, then it will be $250 for the monitor, a very good price I think.
Specs from Acer site:
Acer® AL2216Wbd (BLACK)
Size/Type
22" wide-screen TFT LCD
Native Resolution
1680 x 1050
Contrast Ratio
700:1
Horizontal Viewing Angle
170°
Vertical Viewing Angle
0.282mm
Audio
No speakers
Signal Connectors
VGA (analog D-sub)
DVI-D (digital)
Chassis Color
Black
Pixel Pitch
0.282mm
Brightness (typical)
300 cd/m2
Response Time (typical)
5ms
Colors Supported
Up to 16.7 million
Power
Voltage: 100-240V
AC Adapter: internal
Power consumption: 55W
Kensington® Lock
Supported
VESA Wall Mount
Supported
Front-Panel Controls
Auto
Power
Back / Forward
Menu
Dimensions & Weight
20.2" (514.0mm) W x 7.8" (198.0mm) D x 16.0" (406.0mm) H
10.6 lb. (4.8kg)
Limited Warranty*
Three-year parts and labor limited warranty*
Size/Type
Native Resolution
1680 x 1050
Contrast Ratio
700:1
170°
0.282mm
Audio
No speakers
Signal Connectors
VGA (analog D-sub)
DVI-D (digital)
Chassis Color
Black
Pixel Pitch
0.282mm
300 cd/m2
5ms
Colors Supported
Up to 16.7 million
Power
Voltage: 100-240V
Kensington® Lock
Supported
VESA Wall Mount
Supported
Auto
Power
Back / Forward
Menu
Dimensions & Weight
10.6 lb. (4.8kg)
Limited Warranty*
