Originally posted by: mazeroth
CC's restocking fee says 15% on computer items. Does this adhere to that? I sure hope not!
I was told yes.
No problem. I'm using DVI, but CRTs use analog and they can go to much higher resolutions than that. It's probably your video card, or drivers. What video card do you have? If it's integrated, how old is it?Originally posted by: msnbcnnbcbs
anyone else having any trouble getting this monitor to do 1680x1050?
1440x900 is the max i can get it to go. or is it because im using analog input?
coupon says "in store only"Originally posted by: amd4life
can you order this online and then have the price adjusted once it arrives at the local store?? or is there anyway to input the code online?
You can download the $40 coupon here.http://www.zshare.net/download/cc40off-pdf.html
Originally posted by: NICKel
What do you guys think of the extended warranty??? Circuit City Advantage Protection Plan for 4 years on Acer AL2216WBD
$69.99
$69.99
I am going to skip it. Monitor already has a 3 year warranty. Hope to go tomorrow to pick this monitor up. I had already been looking at it for the past 2 weeks was just waiting for a sale.
Go for it.Anyone that used the coupon successfully have any words of wisdom for me.
You can tilt the screen so it doesn't lean so much.
Mine has some light bleeding at the top but I'm not sure if it's worth it to take it back and try another as it might be worse and could possibly have dead pixels (mine doesn't). It doesn't bother me unless the screen is near black.
Does anyone have a link that shows typical light bleeding on an LCD? This is the first I've ever owned so I don't know what to expect. Other than that I love it. It's going to take some time to adjust from a 21" Sony CRT (going on computer #2) but I'll get used to it.
