I'd just lookup some GPU reviews since the gpu is typically the most power hungry component for many builds, and review testbeds will have some high end cpu to not bottleneck the gpu. For example the total power consumption for an Nvidia 2060 is ~250W. Even if the review website only gives the gpu power consumption, its not difficult to work out the total power consumption by checking some cpu reviews.As title states, I am looking for an accurate online Power Estimator. Any help would be much appreciated. Thanks
Thanks, I will take a look @ max power from gpu & cpu and add an extra 50W for m/b, ram, Optical Drive 🙂)), NVMe drive/s, SSD/s and a spinner or two. I think that should cover with headroom the extra over cpu & gpu. I did not even think to look at reviews for worst case scenarios, again, Thank You!
