- Jan 21, 2006
- 3,695
- 1
- 0
the formula for power loss in a component is ...
P= (V^2)/R
in one of the other threads, somebody was asking about raising the CPU voltage .05 volts in conjunction with a CPU freq. increase from 2.4 to 2.5 GHz (on an AMD X2 3800)
i doubt that calculating the increase in power consumption is as simple as calculating the ratio (1.4^2)/(1.35^2), the ratio between the 2 voltage levels, squared. since the frequency is raised at the same time.
can anybody provide a fairly accurate formula for calculating the energy consumption of a CPU ? e.g. by curve-fitting data from TH or A'Tech ?
thanks !
