Accounting Exam Review help... thanks
MikeMike
45,885
66
using job costing system...
on Jan 1 they have
Work In progress of $62,000
During the year, materials requisitioned for use amounted to $110000, of which $79,000 represented direct materials..
Factory wages for the period were $242000, of which $199,000 were for direct labor.
Manufacturing overhead is allocated on the basis of 80% of direct labor cost.
Actual overhead cost for the year was $125000
Jobs Costing $350,000 were completed during the year.
The December 31 work in process inventory balance is?
the answer is $149,200
but i have yet to figure out what gets me that number...
GoodRevrnd
6,801
581
How sure are you of answer? I don't remember so good from budgeting class, but I get:
MatUsed (DM?) + DL + MOH = MfgCosts
BegWIP + MfgCosts - EndWIP = COGM
EndWIP = $449,200
MikeMike
45,885
66
EndWIP = $449,200
sure enough that its the answer given online by the accounting program we use...
your math is off, and honestly gives $115,000, which IS another possible answer, but not the "right" one...
JJChicken
6,165
16
bump? exam in 3 hours, jsut trying to figure this question out.
Didn't boomer send you a PM?
Anyways, I think the answer is wrong. This is a pretty simple question.
WIP = Beginning + Manufacturing for the year - units transferred out
Manufacturing for the year = direct materials + direct labour + manufacturing overhead (I think? It's been a while since I did this stuff)
MikeMike
45,885
66
his number (reading his "spreadsheet" properly) seems to be $30k...
JJChicken
6,165
16
COST OF GOODS MANUFACTURED
The cost of goods manufactured statement combines all the direct materials, direct labor and factory with beginning work in process inventory, minus the ending work in process inventory, to report the total cost of the goods which have been manufactured during the period. In order to prepare the statement, a manufacturing summary is debited for all the costs during the year, and credited for the cost of goods manufactured and ending inventories. The cost of goods manufactured is added to finished goods inventory to sum to the goods available for sale, which gives the cost of goods sold when ending finished inventory is deducted.
^^^ I did a quick google search and got that.
MikeMike
45,885
66
i know that...
here is a screenshot (copying isnt allowed) of the question, with the "$149,200" shown as a green check (aka correct, also verifiable by having 1 question answered correctly, aka the only question i answered this time through)
JJChicken
6,165
16
EDIT: Your OP has the wrong jobs transfered out number ><. I've updated.
Okay, I brushed off my Chartered Accountant notes. This is what I got:
Two costing systems: Actual (uses actual overhead rates) & Normal (fixed overhead rates). Normal costing is typically applied to process costing systems because the processes are more repetitive. However, we're given that manufacturing overhead is allocated based off 80&#37; labour, so I think we can presume a normal costing system. If this sentence was not there, I would advise you to use actual overhead rates (since we are looking at a job costing system).
Beginning work in progress (01.01) = $62,000
Direct Materials used = $79,000
Direct Labour used = $199,000
Manufacturing (Direct) Overhead = 0.8 x D.L. = 0.8 * 199,000 = 159,200
Units transferred out = $350,000
Therefore, Ending WIP (12.31) = 149,200 (as required).
I'm fairly certain with this answer, since I read all the relevant points from my studies. Read the below about manufacturing overhead, it explains why we disregard the remaining indirect materials/wages/actual overhead from our calculation:
Manufacturing overhead (also known as factory overhead, factory burden, production overhead) involves a company&#8217;s factory operations. It includes the costs incurred in the factory other than the costs of direct materials and direct labor. This is the reason that manufacturing overhead is often classified as an indirect product cost.
Generally accepted accounting principles require that cost of direct material cost, direct labor, and manufacturing overhead be considered as the cost of products for valuing inventory and for determining the cost of goods sold.
MikeMike
45,885
66
I got the answer finally...
it's
Manuf Overhead = DL *.8
159,200 = 199000 * .8
WIP Beg + DM + DL + Manuf Overhead - Completed = 149,200
62000 + 79000 + 199000 + 159200 - 350000
the .8 was screwing me hard.
SandEagle
16,809
13
ATOT isnt your personal tutor. i didnt have internet when i took accounting years ago. kids these days are lazy and dont want to work hard anymore. i hope u fail.
j/k. dont fvck up and good luck
GuitarDaddy
11,465
Beg WIP 62,000
Add dir mat'l 79,000
Add dir labor 199,000
Add O/H 159,200 (199,000 x 80&#37;)
Sub cost of sales (350,000)
Ending WIP 149,200
Opps, see you already figured it out
