Accidentally made my External Hard Drive a Recovery Disk
stished
8
Hi Everybody
Here is the scenario:
I was trying to remove the pre-installed Windows 8. I figured I should create a backup in case I ever have to go back to the piece of junk software. Anyway, I plugged-in my external hard drive to make the backup...
Here's the **ck up:
It said 'formatting drive'. Within two seconds, I cancelled the operation and removed the hard drive.
Now, when I try to access it (tried on 3 other laptops), it just shows the Hard Drive as Recovery Disk with some 20MB data and total 30 GB space.
Disk management shows 890 GB unallocated space.
It's a seagate 1TB backup drive. There was nearly 500 GB of data on it.
Do I need to use some data recovery program or is there another way. I don't think an entire hard drive can be formatted in 2 seconds.
Can someone please help. I can't stress enough how important the data on the drive is to me.
Regards
Stished
Oldgamer
3,280
Why was it formatting the drive? Was this a brand new external hard drive?
KriB
14
The tool wanted to make a bootable disk so you can run recovery from it, hence the format, I would guess....
stished
8
Hey
Used R-studio and recovered almost 100% of the data. Just made a backup of the backup.
Cheers
