Question accessing os when fTPM is enabled and W11 is installed if mobo died
daggs1
229
9
Greetings,
with the upcoming launch of W11 I see that fTPM is a must.
when enabling fTPM in the bios, there is a note states that if the mb is replaced or the key is lost, the os will be locked and encrypted.
mobos which die aren't a new thing, it happens.
how I can make sure that in case one of my mobos die, I can still access the os for either files rescue or even mb replacement?
Thanks.
VirtualLarry
56,587
10,225
daggs1
229
9
so, assuming I export the privte key and save it somewhere safe, I should be able to access the device even if I change HW?
OlyAR15
982
242
Actually, I'm not sure if the drives get encrypted at all. At least when upgrading from W10 to W11. I have 6 machines running 11 right now: 2 on Home, 4 on Pro. Neither of the Home machines appear encrypted, even though one is running on a MS account while the other is a local account. Of the 4 running Pro, I only enabled Bitlocker on one (and that was when it was running W10). None of the others have it enabled by default, even though one of the machines is on a MS account.
So I'm not sure if W11 Home encrypts drives by default. Possibly, if doing a clean install, it may, since Home requires you to use a MS account, but right now I have no way of verifying it. If it does encrypt, the encryption key will be stored on your MS account.
OlyAR15
982
242
so windows is now a os that cannot work without network?
Yes, it works fine without a network. You can still log onto your MS account without an internet connection. It's just that, for whatever reason, MS has decided that W11 Home requires users to use an MS account when they first set up their computer. After that, you can switch to a local account. W11 Pro still allows use of a local account when first setting up a PC.
Obviously, upgrading a pc from W10 to W11 bypasses all of that.
