Access question
snidy1
1,285
I'm trying to figure out how I can retrieve only records from todays date - 6 months. I just want to list employees that have been here under 6 months.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Set the query to calculate a date range
DATE less than today and DATE+180 greater than today
DATE is the datafield
You may have to research how to do the calculation.
Zontor
530
Been years since I used access (use MSSQL now) but from memory:
SELECT * FROM foo WHERE the_date <= DateAdd("m", -6, now());
You may want to modify this a bit to either include or exclude your endpoints.
I think you only need to wrap literal dates in the # symbols....
Edit: Decided to look up something....maybe want to use date() instead of now() although it should work.
This should help you too.
