Access program not running in taskbar or system tray?
OCNewbie
7,596
25
I fired up Prime95 and have it running currently. I was testing minimizing it to tray or to taskbar, and I've made it disappear from both now, but it's still running under the "Processes" tab on Task Manager. Just wondering if there was any way to switch to a a program that is only listed in the Processes tab, not listed in taskbar or systray. Thanks! =)
(Yes, I know I can "End Process" if I want, but I just want to see how long it's been running, etc.)
Edit: Alt-tab doesn't work as well, thanks =)
Crusty
12,684
I've been able to use alt-tab to get to programs in the past where that has happened, but sometimes it just doesn't work either :p
OCNewbie
7,596
25
Originally posted by: KeypoX
what happens if you open it again? Does it just open another?
good question, didn't try that though =) I just ended the process a while back. Thanks for the reply though!
