Hi people!
I am new to access - just 1 month or so- and I have made a small database step-by-step. I use Win XP sp2 and Office 2002. A few days ago I decided to format the C partition devide it in 2 other logical partitions in order to keep windows in one and program files in the other. The reason is to try keep windows more stable with less entries in the drive and faster recovery after the next format ( Of course I can use your opinion on this too!).
Anyway I found out that the buttons I have designed in the access forms were creating an error: Missing reference to Cal3aS.dll- wrong version, bla,bla, try to change it ! And then the debugger was pointing to the button_click subroutine. Even when I redisigned the button the problem was the same.
Is it a trivial problem?
What does it mean and how I can fix it?
Since I am novice on this area , I am open to any suggestion, so don't take advantage of this!
Thanks in advance,
D.
Thanks in advance,
D.
