Access help: VB
minendo
35,560
22
What I am trying to do is filter a report using criteria set in a form based on the data input in the database. I've got my form, filters, etc set, but for some reason the attached code does not work.
Private Sub Set_Filter_Click()
Code:
Dim strSQL As String, intCounter As Integer
  For intCounter = 1 To 4
      If Me("Filter" & intCounter) <> "" Then
         strSQL = strSQL & "[" & Me("Filter" & intCounter).Tag & "] " _
             & " = " & Chr(34) & Me("Filter" & intCounter) & Chr(34) & "" _
             And ""
      End If
  Next
  If strSQL <> "" Then
     strSQL = Left(strSQL, (Len(strSQL) - 5))
     Reports![date_report].Filter = strSQL
     Reports![date_report].FilterOn = True
   End If
End Sub
Any ideas as to why I keept getting an error on the strSQL = command?
KLin
30,950
1,076
Code:
             & " = " & Chr(34) & Me("Filter" & intCounter) & Chr(34) & "" And ""
      End If
  Next
   End If
End Sub
See if that works?
minendo
35,560
22
See if that works?
Nope. Still errors on:
Code:
KIAman
3,342
23
Why are you double quoting this?
Code:
"" And ""
Remove double quotes. And if you MSUT double quote there (for some reason) then use what you have been using before and stay consistent: char(34)
KLin
30,950
1,076
Code:
"" And ""
lol That's the problem. Just tested it out myself and it works when taking out those double quotes.
minendo
35,560
22
Code:
"" And ""
Removing that helped, but for some reason it does not accept the values from my combo boxes. Instead I get a popup asking to input parameter. Any ideas?
KLin
30,950
1,076
When you open the properties for each field(design view, click field, F4 key) and click the other tab the name property needs to match "filter1", "filter2" and so on.
minendo
35,560
22
All are set that way. It runs through the filter names properly. Do they need to have a control source set?
minendo
35,560
22
For example Filter 1 properties are:
Row Source Type: Table/Query
Row Source: SELECT Main.[Item #], Main.Date FROM Main;
KLin
30,950
1,076
Are you familiar with stepping through code in vba? You may want to see what strSQL is ending up looking like before setting it to the report's filter property.
minendo
35,560
22
Not at all. I haven't used VB since 10 years ago. I'm just trying to create a simple database with a filter option for the one of the reports.
KLin
30,950
1,076
Change Me("Filter" & intCounter).Tag to Me("Filter" & intCounter).Name and give it another try
minendo
35,560
22
How do I set the FilterOn expression in a report?
Edit: Nevermind figured filteron out. Still can't figure out why report does not filter.
KLin
30,950
1,076
PHP:
Dim strSQL As String, intCounter As Integer, first As Boolean
first = False
    If Not IsNull(Me.Filter1) Then
        first = True
        strSQL = "[ReportField1] = '" & Me.Filter1 & "'"
    End If
    If Not IsNull(Me.Filter2) Then
        If first Then
            strSQL = strSQL & " AND "
        Else
            first = True
        End If
        strSQL = strSQL & "[ReportField2] = '" & Me.Filter2 & "'"
    End If
    If Not IsNull(Me.Filter3) Then
        If first Then
        Else
            first = True
        End If
        strSQL = strSQL & "[ReportField3] = '" & Me.Filter3 & "'"
    End If
    If Not IsNull(Me.Filter4) Then
        If first Then
        Else
            first = True
        End If
        strSQL = strSQL & "[ReportField4] = '" & Me.Filter4 & "'"
    End If
    End If
End Sub
Try that out. You need to change each ReportField to be whatever field you want to filter by in the report. (ie change ReportField1 to [Item #] in the code above and the same thing for the other 3).
minendo
35,560
22
PHP:
first = False
        first = True
    End If
        If first Then
        Else
            first = True
        End If
    End If
        If first Then
        Else
            first = True
        End If
    End If
        If first Then
        Else
            first = True
        End If
    End If
    End If
Gave me the following error: Data type mismatch in criteria expression.
minendo
35,560
22
Will this allow me to filter by just one filter or must all filters have data selected? I am needed to filter by any combo (sometimes just 1, other times multiple).
KLin
30,950
1,076
It will allow any combination of the combo boxes filled out. Are any of the combo boxes numeric values or dates?
minendo
35,560
22
The first combo box is a date. Two are text, and one is linked to a Yes/No field.
Would it be easier if I were to send you the file to review? Right now it is just filled with bogus data until I get it working properly.
KLin
30,950
1,076
That's fine. I'm at home sick and kinda bored. YHPM
