Accelero S1 and Thermaltake Armor w/ 25cm fan
emfiend
Anyone have this combination? My MB is the ga-p35-ds4. I'm thinking of getting a better cooling solution for my 8800gt but I can't tell from the measurements on the Arctic Cooling website if the accelero will fit into my case. Main conflict seems to be the possibility of my side 25cm fan on my case hitting the Accelero. It "kind of" looks like it will fit but then it "kind of" doesn't.
I *think* it'll fit. If they have a pdf with the full dimensions of the heatsink that'll be what you need, you'll need to figure the width of the heatsink and fins from the center of the GPU so you can measure from the backside of the card.
Yep. Checked the pdf from the AC website but it didn't really give me the assurance that it would fit. If the alignment is poor between the case fan and the heatsink, I know for a fact that it won't fit. But if the fan is high enough on the panel, the heatsink *may* miss it and therefore fit fine. It would be nice to know from someone who actually has this combination of parts.
