- Apr 28, 2004
- 1,187
- 0
- 86
I am assembling a computer out of old and new parts (The case being one of the older parts that has an AC'97 Front Panel Connector) I am using a Gigabyte GA-MA770T-UD3 as the motherboard and it supports HD Audio and AC'97 for the front panel connector (Selected in the BIOS) So my questions are.
1. Is there any significant differences between HDA and AC'97 (Other then the wiring?)
2. Can I rewire the front panel cable to an HDA connector or do I need to replace the jacks themselves?
I am only going to use the jacks for a Pair of headphones and a Mic (Both occasionally so the jacks would be empty most of the time
Thanks
Thanks
