It has been well established by Telsa, that AC for power lines is both more convenient and more efficient than DC. While it is easy to understand the former, I have never fully understood why AC should be more efficient than DC.
This following excerpt (from http://en.wikipedia.org/wiki/Alternating_current) also confuses me:
"Use of a higher voltage leads to more efficient transmission of power. The power losses in the conductor are due to the current and are described by the formula P = I2 * R, implying that if the current is doubled, the power loss will be four times greater. Therefore it is advantageous when transmitting large amounts of power to convert the power to extremely high voltages (sometimes as high as hundreds of kilovolts)."
Power equals I*I*R, but it also equals V*V/R. It seems to me that R (the resistance in power lines) will be fixed and should be kept as low as possible, so that increasing V will also increase power consumption according to the second formula.
Thoughts?
UPDATE:
The only details from the comments below which makes sense is the non-linearity of the resistance with current.
I understand the transformer utility for AC, but I think Telsa also argued that AC was more efficient (i.e. used less energy) than DC. Maybe it had nothing to do with the mode of transmission but the "inefficiency" of DC-to-DC conversion.
Thoughts?
UPDATE:
