I have a 1993 cavalier had great ac till the clutch went out on my compressor. The repair shop said your ac system is 20 years old you really need a NAPA cool kit new compressor oil orings dryer and 134 all in a kit installed for 600.00 I let them do it it was an r12 system. I pick it up like last night the outside temp 83 high humity vent temps were 50 moving but at red lights the temp went up fast to 65 on hot days at idle in traffic its like I have no ac the shop attitude about it stinks they said we could put on pusher fan for 200 more but no garantee that would fix it another ac person told me he would change the condenser to a parallel flow its about 100 on line plus labor to install . it would help the 134 in traffic and give you lower vent temps he also said you may need to change the valve on the back of the evaporator any advice would be helpful I did notice if I rev the motor at idle it will start to cool better could I have a weak compressor . I am leaning toward a new condenser I have clean the front of my old condenser I do have an aftermarket fan motor and a new radiator my coolant temps in traffic are good but poor ac proformance.
