AC Freezer 64 Pro installation trouble
wongnog
51
Hey guys. I picked up a freezer 64 last night to put in my asus a8n-sli premium with opteron 165. I had soem trouble putting it on, tried to do it with the mobo still in the case but that didn't work. Took the mobo out, but my concern is that the clip mechanism seems to be at an angle on the side with the lever you have to lock down. Let me try and explain...
I released the screw on the lever so I could have the locking mechanism on the opposite side from stock. So when looking at the unit from the rear of my case, I am looking at the fins of the cooler with the fan of the freezer behind it -- that's normal. I fit the lugs over the retention module on the *left* side of the Freezer first (opposite from stock), then lower the lugs on the *right* side and lock the hinge on that side. But the lugs and the hinge on that right side are all at an angle, they are pointing towards the cpu. I expected them to be perpendicular to the mobo. But despite this and the fact it took me no less than a dozen tries to get the locking mechanism down, I still reduced my SP2004 load temps from a high of 61° to a cool 53°. OCCT stability test peaks only at 45°. So basically... am I okay?
dustmann
341
Mine leans a little bit towards the cpu, not much, I didn't even notice till I looked. Anyways I think if your temps are lower don't worry about it.
MadScientist
2,186
63
My lever and clip also lean towards the CPU. The trick to installing this HS is to make sure that the clip on the lever side is loose and at it's lowest position. The clip has a tendency to hang up, making it almost impossible to attach to the 3 plastic tabs on the retention mechanism.
Follow steps 6 and 7 of the installation instructions: AC Freezer64 Pro Installation Instructions
If the clips have fully engaged the 6 plastic tabs (3 on each side) on the RM after the lever's locked, you're good to go.
Tullphan
3,507
I broke one of the middle tabs. I hope it don't hurt anything. I think i'm gonna lap my AC Freezer64 Pro, tho. I don't think the temps are as low as they should be considering my setup.
