I have here a AC-DC converter. It takes a 120 VAC 60 Hz signal and converts it to 12 VDC. Does it actually output a solid 12 VCD? Or does it take the 120 VAC sine wave, make the negative parts positive, and squish it down to 12 V amplitude?
The reason I ask this is I need to use the adapter in Europe. To get my 120 VAC I will be using a converter on the 240 VAC over there. As far as I know this converter chops the 240 VAC sine wave off, rather than shrinking it down like a transformer would. Will this cause any difficulty for the AC-DC adapter?
Also will the 50 Hz vs 60 Hz be much of an issue? The AC-DC adapter is low power usage so I don't expect an overheating problem.
