AC adapter help
blyndy
33
Hi, I've got a notebook that is missing its original AC adapter. The original was rated at 16V/ 4.5A/72W. The closest I have is a 13V/4.2A adapter. Assuming the adapter can exceed its rating by 300mA, would the undervoltage be passed the damage threshold?
HalfCrazy
853
You could try calling the company who made your laptop. You will be able to order a new AC adapter for your laptop. Radioshack also sells AC adapters for laptops. But your best bet in the company who made your laptop.
Chances are the AC adapter won't exceed its rating.
ChaiBabbaChai
1,090
eBay.
don't use the wrong power supply for anything like a computer ever. For like, transistor based guitar pedals it's cool, but not a computer.
corkyg
Elite Member | Peripherals
27,370
240
Most laptops have a tolerance of +/- 1 vdc or 5%. Your difference is 26% down. Don't!
Blain
Don't try and use something you happen to have laying around.
Buy This and move on with your life. ^_^
Blain
You need to search and find out if your notebook requires an OEM adapter or if it will run and charge with an aftermarket model.
An issue that some people are running into is that an aftermarket universal adapter will run their notebook but not charge it.
I purchased a CoolerMaster SNA95 universal adapter. Buried deep in the manual it says...
"Some Notebooks have ID patent for their own adapters. However, this product will have no problem powering the laptop regarding the above issues, but may not be able to charge due to ID patent of the notebook."
spikespiegal
1,219
9
Using an undervoltage adapter will not only cause your laptop to not run properly, it will likely cause your adapter to heat up and likely burn out.
ecom
479
Also you need to ensure that the polarity on the plug is correct. Don't just plug any random adapter because reversed polarity can cause serious damage.
