I will be setting up a system with a Q6600. Will not overclock at first. Maybe just a little eventually. I am not going to push it to extremes and am not sure how a super huge cooler will fit in my case (P150) or affect airflow.
So my goal is to find a cooler that will do a little better than stock for temps, that will be a little bit quieter than stock, won't be huge and will be fairly easy to install.
I have narrowed the search to the Artic Cooling 7 Pro or Cooler Master Hyper TX2. As I think they both will perform similarly.
Some reviews on newegg seem to say the AC 7 Pro is not built well and may fall apart upon installation.
Does anyone have any preference to one over the other or any major pro or con with either?
