Originally posted by: jrwalte
I use this heatsink. Yes, it is a 4-pin PWM fan. It can run extremely quiet without any PWM noise at low speeds. I can get mine to 200-300RPM.
Just to make sure, you're talking about the Freezer 7 Pro?
