about logitech mouse software scrolling problems.....
erichui
86
ok.
i got a logitech mouse, and i am fully happy with it, except that when like i scroll in ACDsee and etc, like scrolling thru pictures, the logitech software always goes thru 2 pictures , and this is become very annoying, it never happened with my microsoft mice, so i think its the problem with the logitech software??
anyone know the solution?
SHoddyCOmp
2,072
Do you mean how fast the scroll wheel scrolls? I think there is an adjustment somewhere for that...
erichui
86
no, i dont mean that,
ok,
i dont know what kind of example to say, but only what i got problems with, which is with ACD See.
like when u browse through photo only, and using ur wheel to scroll thru photos, when u scroll down it should go to the next image, and when u go up it should scroll to previous image.
however, with the logitech, instead of scrolling thru only 1 image, it does 2, so like when i am on photo number 2, moving wheel down will scroll the photo to photo number 4 instead of 3,
and its getting annoying.
any help will be pleased.
stevewm
742
This has been a bug in the Logitech Mouseware since it was created.
Uninstall Mouseware and you'll find that your scrolling problem is solved.
Unless your mouse has some extra programmable buttons you want to use there is no reason to have Logitech's software installed. The mouse will work just fine with the standard windows mouse driver.
gsaldivar
8,691
If Logitech would only fix this problem, they would have a perfect product on their hands.
As far as I know, other than removing the MouseWare drivers (and losing the extra mouse button features), there is no fix for this problem. I started switching to Microsoft Mice because of the endless problems with the Logitech scrolling...
Sorry I couldn't be of more help.. :)
