- Oct 11, 1999
- 15,581
- 1
- 76
At a fixed RPM value, how much does the throttle affect the power output of an engine? For example, say you have at some moment in time, you have an engine running at 3000 rpm. In case A, you had the gas pedal floored, while in case B, you had only light pressure on the gas pedal. How much power difference at 3000 rpm would there be in case A and B?
The reason I ask is cause I was merging onto the freeway today and had the gas pedal at some leisurely position. I was suddenly going 80 and I was a little surprised because I was going real easy on the gas.
