About Collazt Conjecture
Discussion in 'Distributed Computing' started by TennesseeTony, Apr 25, 2017.
  1. StefanR5R
    StefanR5R Senior member
    Dec 10, 2016
    697
    301
    I agree that it is very worthwhile to search this thread at the Collatz forum, or at other forums like OCN's, for configurations for GPUs that are similar to one's own. Even if you don't end up with the precise optimum set of parameters for your GPU, chances are good that you still get much better results than with the default parameters. Of course if you have the time, you can very easily test out how the parameters affect your particular card.
    I'm distilling some information about the various parameters from the Collatz forum now. I'll post some actual results from my own GPUs later.
    Configuration file locations (on Windows, replace the first path components on other OSs accordingly):
    C:\ProgramData\BOINC\projects\boinc.thesonntags.com_collatz\<app_name>.config​
    During project initialization on your client, empty <app_name>.config files will be created for each of the application versions that match your GPUs. You can enter parameters into these files in order to deviate from default values, and they will be picked up as soon as a Collatz GPU task starts.​
    Configuration file format
    Plain text file, one "parameter=value" pair per line, unrecognized parameter names are simply ignored (you can use this to comment out some parameters during testing), missing parameters fall back to their default values.
    Example (suitable for a GTX 1080):
    kernels_per_reduction=48
    threads=9
    lut_size=17
    sieve_size=30
    cache_sieve=1
    Parameters
    cache_sieve
    default: ?
    range: 0 or 1 (?)
    definition: ?
    default: 32
    range: 1...64
    definition: "the number of kernels that will be run before doing a reduction. Too high a number may cause a video driver crash or poor video response. Too low a number will slow down processing. Suggested values are between 8 and 48 depending upon the speed of the GPU."
    comment: "affects GPU usage and video lag the most from what I [sosiris] tested."
    lut_size
    default: 10
    range: 2...31
    definition: "the size (in power of 2) of the lookup table. Chances are that any value over 20 will cause the GPU driver to crash and processing to hang. The default results in 2^10 or 1024 items. Each item uses 8 bytes. So 10 would result in 2^10 * 8 bytes or 8192 bytes. Larger is better so long as it will fit in the GPUs L1/L2 cache. Once it exceeds the cache size, it will actually take longer to complete a WU since it has to read from slower global memory rather than high speed cached memory."
    comment: "I [sosiris] choose 16, 65536 items for the look up table because it would fit into the L2$ (512KB) in GCN devices. IMHO it could be 20 for NV GPUs, just like previous apps, because NV GPUs have better caching."
    reduce_cpu
    default: 0
    range: 0 or 1
    definition: "The default is 0 which will do the total steps summation and high steps comparison on the GPU. Setting to 1 will result in more CPU utilization but may make the video more responsive. I have yet to find a reason to do the reduction on the CPU other than for testing the output of new versions."
    comment: "I [sosiris] choose to do the reduction on the CPU because AMD OpenCL apps will take up a CPU core no matter what you do (aka 'busy waiting') and because I want better video response."
    sieve_size
    default: ?
    range: 15...32
    definition: "controls both the size of the sieve used 2^15 thru 2^32 as well as the items per kernel are they are directly associated with the sieve size. A sieve size of 26 uses approx 1 million items per kernel. Each value higher roughly doubles the amount. Each value lower decreases the amount by about half. Too high a value will crash the video driver."
    sleep
    default: 1
    range: ?
    definition: "the number of milliseconds to sleep while waiting for a kernel to complete. A higher value may result in less CPU utilization and improve video response, but it also may lengthen the processing time."
    threads
    default: 6
    range: 6...11
    definition: "the 2^N size of the local size (a.k.a. work group size or threads). Too high a value results in more threads but that means more registers being used. If too many registers are used, it will use slower non-register memory. The goal is to use as many as possible, but not so many that processing slows down. AMD GPUs tend to work best with a value of 6 or 7 even though they can support values of up to 10 or 11. nVidia GPUs seem to work as well with higher values as lower values."
    comment: "I [sosiris] didn't see lots of difference once items per work-group is more than wavefront size (64) of my HD7850 in the profiler."
    verbose
    default: 0
    range: 0 or 1
    definition: "1 will result in more detail in the output."​
    Definitions are taken from Slicker's post from June 2015, last modified in September 2015.
    Comments are taken from sosiris' post from June 2015.
    #26 StefanR5R, Jul 23, 2017
    kowalabearhugs likes this.
  2. StefanR5R
    Dec 10, 2016
    697
    301
    Here are results from a few GPUs without and with custom parameters.
    AMD W7000 (similar to Radeon HD7870)
    host: i7-4960X@4.2 GHz, Windows 7 Pro
    Code:
    configuration         default (empty)           kernels_per_reduction=48
                                                    threads=8
                                                    lut_size=16
                                                    sieve_size=29
    throughput            ~1 M PPD                  1.3...1.4 M PPD
    NVIDIA GTX 1700
    factory-OC'd card, 170 W power target per factory, x 114 % manual power target
    Code:
    configuration         default (empty)           kernels_per_reduction=48  kernels_per_reduction=48
                                                    threads=8                 threads=8
                                                    lut_size=17               lut_size=17
                                                    sieve_size=28             sieve_size=30
    avg core utilization  98 %                      98.5 %
    avg task duration     870 s                     500 s
    avg task credits      37 k                      31 k
    throughput            3.65 M PPD                5.3 M PPD                 5.7 M PPD
    avg power draw        ~179 W                    179 W
    energy efficiency     0.24 PPJ                  0.34 PPJ                  0.36 PPJ
    NVIDIA GTX 1800
    180 W board power, x 90 % power target
    host: E5-2696v4@2.2 GHz, Windows 7 Pro
    Code:
    configuration         default (empty)           kernels_per_reduction=48  kernels_per_reduction=56
                                                    threads=9                 threads=9
                                                    lut_size=17               lut_size=18
                                                    sieve_size=30             sieve_size=30
                                                    cache_sieve=1             cache_sieve=1
    avg core utilization  98 %                      98.5 %                    98 %
    avg task duration     ~770 s                    360 s                     517 s
    avg task credits      ~36 k                     28 k                      29 k
    throughput            ~4.0 M PPD                6.3 M PPD                 4.9 M PPD
    avg power draw        154 W                     158 W                     159 W
    energy efficiency     0.30 PPJ                  0.46 PPJ                  0.36 PPJ
    NVIDIA GTX 1800Ti
    250 W board power, x 90 % power target
    Code:
                                                    threads=9                 threads=9
    avg core utilization  65.8                      95.4 %                    96 %
    avg task duration     ~770 s                    277 s                     275 s
    throughput            ~4.0 M PPD                8.7 M PPD                 9.1 M PPD
    avg power draw        197 W                     219 W                     219 W
    energy efficiency     0.24 PPJ                  0.46 PPJ                  0.48 PPJ
    Conclusion: The default parameters are conservatively chosen, so that small GPUs run the application properly. The larger your GPU, the more performance uplift can be gained by custom parameters, combined with increased energy efficiency. Too large settings can have a detrimental effect though (rightmost column in the GTX 1080 table).
  3. crashtech
    crashtech Diamond Member
    Jan 4, 2013
    7,165
    464
  4. StefanR5R
    Dec 10, 2016
    697
    301
    Our 28 days result is almost double of theirs, but their 7 days result is almost double of ours (and is a quarter of their 28 days result). In other words, Crunching@EVGA haven't finished the Collatz sprint yet.
  5. crashtech
    Jan 4, 2013
    7,165
    464
    Does it really take that long to get work validated? I've put some GPUs towards Collatz just in case.
  6. Kiska
    Kiska Senior member
    Apr 4, 2012
    447
    66
    Work validation is usually instant for collatz that is
  7. StefanR5R
    Dec 10, 2016
    697
    301
    @crashtech, I meant to say it appears as if they keep going in full-on sprint mode. Looking closer, they did 220 M points in the sprint (3...4 days), and "only" 144 M points in the last 7 days. IOW not all but a few of their members missed that the Collatz Conjecture sprint is over now. ;)
    Ken g6 and crashtech like this.
