- May 18, 2001
- 24,117
- 2
- 0
Hi all,
I have a Siluro GF3 Ti200, bt the active cooling seems a little lame. I can only get 240-245 out of the core without Artifacts in 3DM2K1, to get a 7700 score.
The Memory only goes to 450 without artifacts and i think this is due to heat leakage from the core. The back of the card of roasting hot to touch, leading me to believe the HSF aint doing all that much.
The HSF is only luke-warm to the touch.
I have a 40CFM Ball bearing fan intake at the front, same at the back, slot exhaust fan and an Enermax 350W PS with it's usual 2 fans.
NB: Anyone with an Enermax may have found they get a hot spot at the top of their case in front of the PSU. This is due to leakage thru the slots in the PSU inside the case. These leak when the air from the lower fan is running faster than the outtake. I have resolved this by sealing these slots, thus allowing the temp governed fans to take up the extra heat created in the PSU. Hot spot now gone!
Case is GW802 (Of course!) Other Specs in sig.
