- Nov 22, 2001
- 2,806
- 0
- 0
I remove stock mobo cooling solutions mainly to apply as5 on the chipset; but I also like to see what kind of job mfr's did with thermal interfaces. I'm glad I popped my new Abit P35 Pro's heatsinks off.
While it would have functioned okay, there was poor contact with the moffset heatsink due to a slighly bent heatpipe which was pushing one corner of the heatsink up. Only a couple moffsets were making effective contact.
I straightened things up, reused the moffset thermal pad, used as5 for chipset, and used a good white paste for southbridge.
Overall, I'm not too impressed with this solution. The only copper is the base of the chipset heatsink and the heatpipe; everything else is poorly milled aluminum painted to look like copper. The stock nVidia solution on 680i boards is an example of quality engineering and manufacturing. This Abit solution off the board looks and feels cheap. It may work, but damn they could have done better.
Pics tell the story:
Poor thermal contact with moffset heatsink
Bent heatpipe causing problem
Many little moffsets!
Adequate, but not optimal contact patch for southbridge
Nice clean chipset though!
The underside
The underside
