abit nv7-133R sound have toslink or spdif coax output?
unknown8585
187
the descriptions say the board has spdif, but the picture definately shows a toslink. can anyone verify that it is a spdif coax and not a toslink. thanks
also, is the usb 2.0 attached to th mobo, or do we have a connector to connect the mobo through a pci device or slot.
jacksheartache
>the descriptions say the board has spdif, but the picture definately shows a >toslink. can anyone verify that it is a spdif coax and not a toslink. thanks
Ooof.
S/PDIF is a data protocol for sending digital audio. It can be in either a TOSLINK (optical) or COAX (RCA style) physical format. Both physical formats are still called S/PDIF!
See this for more info about S/PDIF:
http://www.andrewkilpatrick.org/projects/spdif/
Having said that. If you look at the pictures of the motherboard and the add-on ports, it looks like there is only a TOSLINK S/PDIF connector (IN and OUT). So, the specs are just kind of missing the physical format for S/PDIF.
Here are the photos that I found:
http://www.octools.com/index.cgi?caller=articles/nv7133r/ac20.jpg
http://www.octools.com/index.cgi?caller=articles/nv7133r/rig.jpg
I hope this helps. I'm also thinking about buying this motherboard.
