- Aug 16, 2001
- 22,505
- 4
- 81
The fan is grinding pretty bad. I can barely stand posting this. Any replacements or fixes for this?
Originally posted by: FrustratedUser
Thanks! Is it hard to mount?
Yep, very easy to install, too. I love not having to worry about the fan anymore.Originally posted by: o2brew
I have an NF7-S with the above heatsink. Works perfectly.
Um . . . how does it affect your Abit Warranty?Originally posted by: Sonic587
http://www.svc.com/zanoco.html
personally, i'd hate to RMA my MB just for a noisy fan . . . hence my regular cleaning of my NB fan and a drop of oil (think that oil voids the warranty?)Originally posted by: Megatomic
Well, it voids the warranty apoppin. Just like modifying the cooling on a video card. Too me the benefits of improved quiet cooling far outweigh the benefits of a warranty.
Plus, if my NF7-S dies it becomes my opportunity to upgrade to a S939 system. :heart:
I have an (abit) ic7-g with a NB fan that gets 'noisy' . . . it NEEDS to have th dust cleaned out of it regularly or i can hear it progressively complain louder and louder . . .
. . . a drop of 3-in-1 oil under the label worked wonders.![]()
mine sounded the same . . . unbelievable, really LOUD.Originally posted by: FrustratedUser
Well it sounds like it is hitting something. The sound changes when I press/touch the housing.
I do use the onboard sound so I need cooling.
Do I have to take the MB out? That is a major pain. It looks liek the fan is mounted with some kind of spring loaded plastic fasteners. Can these be pulled out or do they unscrew?
Cleaning out the embedded dust and a drop of oil took 'care of it'.
it looks like i'd have to remove my MB to get at the chipset fan. . . . not looking forward to it.
:roll:
