Abit NF7-S and Nvidia System Utility
Alexio
Is it me, or configuration? Since Abit's uGuru doesn't work on NF7-S, I've downloaded Nvidia System Utility to change my settings from Windows. To my surprise, I can't activate the "Advanced panel" of the program - the second (to the left) button stays inactive. Does anybody else have the same problem? Do you know any othe WinXP utility for BIOS tweaking?
Thank yo'all
Same exact issues here. You could try Clockgen, but I prefer the old fashioned BIOS tweaks.
I just got my NF7-S and it came with uguru in the box, I couldnt get it to work, why would they include it if it doesnt work?
The NF7-S doesn't have uGuru hardware, but the AN7 does. That's probably the driver CD, which they throw the uGuru software onto.
Originally posted by: chocoruacal
Thats normal. Check www.amdforums.com, the Abit section. There's a program called 8RDA/NF7 VCore that works great.
That program always causes my comp to crash when using the "Dynamic VCore and Clock Speed" utility at around 180Mhz FSB and then I had to reinstall Windows because of a hardware error. Anyway, there's no easy way to get it to work from my experiences with it.
-Por
