I've had my old Abit N7F2 with Barton 2500+ o/c rig on the shelf for a while, and decided to use it to build a new PC for the wife. I installed it with a 340 watt PS that I know is good, and with some good corsiar dual channel matched ram, a cheap 6200LE video card, etc, and I've been trying to use IDE drives that were just working in my old Linux box in this machine, and install XP. No matter what IDE channel I put the drive on, or if I use one or both of the drives, I am having problems booting and installing from the winXP CD. If I put in a 120gig WD, it never gets past the initial scanning hardware setup of the install process. I put in a 60 gig hitachi, and it allowed me ONCE to entirely install winXP, patch, etc, then crapped out and is now unbootable, but appears to be working physically (might be overheating or something, or not cooperating with the N7F's IDE). I even tried putting the drives in a USB drive enclosure and booting or using them over USB to re-install and no dice.
I have a 200gig WD SATA drive I can use, but the Sata on an N7F2 is an SI addon chip and not in the Southbridge, so the winXP installer doesn't recognize it and see the drive on it, so I can't use that drive for the install. For some odd reason it DOES see the USB multireader I have. I wonder if I can install windows on a big compactflash and then image it over to a HDD... 🙂.
Here's what I'm really hoping I can do: Image the drive I was able to install onto before it crapped out IF it will run in the USB enclosure long enough, and using my PC to image that install onto the SATA drive, and then install the imaged SATA drive into the PC. Not sure if that will work either though. Maybe I should pop the drives into the usb enclosure and try them on my PC to make sure they are really working properly stlll. I can't believe I'm having so much trouble with this board and these old drives after they ran great in my system for 2+ years.
Any headache saving advice anyone can give me on this?
