ABIT KV7 Temperature Issues
bassackwards
I recently setup up this motherboard with an Athalon XP/1800+. The case fans are clean, functional, and positioned correctly yet the onboard temperature sensors indicate that the mainboard temperature is typically between 118-124F, which seems hot to me, given that the cpu temp is typically less than 114 F.
paperfist
6,539
286
www.the-teh.com
I think if you search around you'll find out that Abit sensors are know to report temps a little higher then normal. Something with the math they use to compute sensor temps...
Oh yeah, Welcome to the forums!
boyRacer
18,569
plus... the temp sensor might be somewhere near the CPU where hot air is being blown on it. :)
