Abit KT7A + Radeon 9500 = Problems
Hello everybody!
2 days ago I got my Sapphire Radeon 9500 128Mb graphics card and it's KIND OF working now. Here's my story:
I tried to install the card right away after uninstalling the Detonator drivers for my old GeForce2 card. After i did that I shut down the computer and switched cards. When I started up everything looked fine in "DOS" but in windows I got colorfull artifacts here and there and after like 10 sec my mouspointer dissappeared! It was there but I couldn't see it. then the system would hang.
So I started hunting down the problem.
I updated the BIOS to the latest (think it was A9) and that got rid of the artifacts.
Then I disabled "Fast Write" in the BIOS and that helped for the dissapperaing mouspointer problem. Guess I can live with the loss of performance here.
Now there's only one problem left.
The monitor seems to be refreshing at a very low rate (60Hz?) even though I set it to a higher rate in Windows. Changing settings in Windows doesn't change anything, I still got poor refreshrate.
I've tried ReForce but it doesn't work. I've tried different monitor drivers like plug and play and default drivers (I got a monitor without any naitive driver so I use default) and even drivers that dont belong to the monitor. Nothing works.
What to do now?
Please HELP!
My systemspecs:
Abit KT7A rev 1.0 something (I know it's under 1.3)
AMD Thunderbird 1Ghz
300W Powersupply
384 Mb of PC 133SDRAM Cas2
Harddrives + DVD-player + CD-burner
Nothing more of importance
I HAVE SOLVED THE PROBLEM!
The solution to this problem was simple!
Under the Display properties -> Advanced ->Displays Tab you find a listing of your monitor and some info about them. E.g. the maximum refreshrate the monitor can handle. The problem was that this number was incorrectly sensed as 60Hz (probably because my monitor wasn't supported by XP) so no matter what I tried to set it to in the monitor settings it would set it to max 60Hz!
Yes! Now everything works except "fast write", will take care of that later. Now let's try the software modd that I got from Wizzard to turn my card into a radeon 9700!!
/ PowerSupply
