abit kt7 raid and floppy problem
trung
9
hi,
My problem is that the floppy on my system sometimes deosn't read or write. It also can't write over something that has been written on. i have changed drives but it is the same. I know it works since the drive can read a startup disk to setup windows.
please help if you can
and i have checked the floppy disk to see if its not write protected
rempe
158
Another kt7 with a floopy problem.Had the same problem with my first one.Rma it and the second one worked fine.Also had probs with the ide
globalshock
may seem stupid but,i've used/seen/fixed abit kt7 god only knows how many times and the only floppy problem I had encountered is people stuffing the ide cables under the floppy(open bottom wheel) it would slow the floppy down making it sometimes work or not. Had this happen 3 times-------Ed
ps- abit is it!!!there is nothing else
