abit kt7 fan grinding/stopping problem
plebeian
34
OK, not the most descriptive of titles but...
My friend has an abit kt7. The fan on the Northbridge (?) chip is acting strange. It pulses on and off, comming to a complete stop every couple seconds, and producing a grinding/droning noise. In and of itself this wouldn't strike me as a problem, since I don't think that active cooling is too necessary on that part. (This is a 800 T-bird/ PC133 system.)
However, this behavior is coupled with a performance issue, namely the mouse is intermitently jerky/freezing for a short period (0.5-1.0 sec). Do these sound at all related?
Is the mouse jerkiness a SW or operating system problem? (We've tried several mice- they act the same.)
Is this a motherboard problem? CPU? Power supply?
Any SWAGs from the esteemed members of this board would be appreciated. Thanks.
BigSmooth
10,484
12
That's really odd. You're right, active cooling is more of a luxury on the Northbridge than anything else... but how this relates to your mouse, I have no idea. The only thing I can think of is a power issue, because weird problems like this can be caused by a flaky PS.
edblor
7,921
Well,
If that particular MB is flaky to begin with (you know, barely passes QC), then the FAN may be the difference between a stable and a not-so-stable system. And the mouse could be acting up because of this.
Drop by your local computer shop and pick up a new 2-pin fan and replace that one. It certainly cannot hurt, and it may very well improve stability/performance!!
G/L either way,
Edblor
GundamF91
1,827
the Northbridge should be fine, especially with it being KT7. most manufactureors don't even put a fan there. but edblor's right, just get a cheap fan and try. it can't hurt getting a better fan. :)
